420W steering wheel universal
Bruce Banning
01-07-2002 13:36:02
I have a slant dash 420W with a worn out steering wheel bushing and universal joint assembly. What is the best way to tighten up this steering wheel assembly ??
Ray
01-07-2002 17:37:28
 Re: 420W steering wheel universal in reply to Bruce Banning, 01-07-2002 13:36:02
I use a truck pto knuckle for the universal.The
bushings are available from JD.If the housing is worn you can install 2 bushings side by side,or
have a good welder build it up.
ChuckW
01-07-2002 15:33:11
the joint is much like that of a 1/2 flexible and I have used those in the replacement of JD.
