Clooney???
Wayne in Tn.
01-07-2002 09:14:37
Clooney, please go to page 2 concerning jumpy clutch question, see if you have anything to add. thanks a lot. Wayne
Clooney
01-07-2002 14:28:03
 Re: Clooney??? in reply to Wayne in Tn., 01-07-2002 09:14:37
~Wayne, if you can't slip it without sudden engagement I'm betting the flywheel & pressure plate are rusty and or pitted & have a very course surface or the lining is actually rusted to the flywheel or pressure plate & pulled loose from the disk. While the 40's have their share of clutch pedal linkage & throw-out bearing wear, that usually causes a difficulty in smooth engagement but will allow slippage & with a little practice a somewhat smooth engagement. Your problem seems as there isn't any slippage at all during the engagement process.
~I don't know any way to check the clutch/flywheel area without splitting the tractor. You can try putting a load on the tractor (not the brakes) then while it is pulling a load keep dis-engaging & engaging the clutch & see if it starts to get better, if it doesn't show an improvement within a short time you will probably have to split the tractor to find out why.
Wayne...Thanks Clooney no text
01-07-2002 15:12:08
 Re: Re: Clooney??? in reply to Clooney, 01-07-2002 14:28:03
notetds
