41B
Chris Tomford
01-06-2002 20:36:55
I plan on starting restoration on my 41B. The old beast runs good, but has some minor oil leaks from the engine, tranny and axle. I don't know if I should go ahead and rebuild the engine and replace gaskets now or leave it be as long as it isn't too bad. I hear that fixing the axle leaks are a bear too. Let me know your opinions!
Thank You!!!!!
Henry J
01-07-2002 07:15:30
 Re: 41B in reply to Chris Tomford, 01-06-2002 20:36:55
I am a first timer myself and I have a 43 B completely disassembled on jacks in my garage. Like your 41B, mine ran before i started the project. However, I found working on the tractor very enjoyable and look forward to a great tractor once I am complete. I recommend you do a complete restoration. The hardest part will be be getting the rear wheels and tires off. Once apart, you will learn how the tractor works and you will find many plugged oil oriffices and ports the affect transmission engine lubrication. The only bad thing about the rear axle seals and felt spacers is cleaning out the dirty gunk insilde the axle housing and tubes.
I thinkyou will find the whole project very rewarding.
