3 point hitch for JD 60
Richard
01-06-2002 17:13:15
What is the difference, if any, on a 800 and 801 hitch? Is this the same hitch on the 70 model JD as would be used on my 60. I was looking at a hitch on photo ads and it was for a 70. Thanks--
JDRon
01-08-2002 15:44:43
 Re: 3 point hitch for JD 60 in reply to Richard, 01-06-2002 17:13:15
The 800 hitch was Deere's first attempt at a three point hitch. It used a claw type bracket on the implement. So dit the 801. The 801 was a weight tranfer type hitch. The hitch was mainly used on the first fully mounted plows. The 801 was an improvement. It used bell housing at the axle brackets the 800 lacked. It had telescoping draft links for easy hookup. It used a cross bar at the center link.
Ron
01-07-2002 06:42:50
I have been looking for the links to convert my 800 to 801.... Anyone have a good set they will sell.????
Ralph
01-06-2002 19:47:24
Richard,
The 800 hitch fit the B through the 70. I'm sure that most of the 800 hitches were converted to the 801. There is a pivot type bracket on the 801 on the rear axe so that when the plow for example pulls harder it pushes harder on the top links. Then links push up on the lift links that put down pressure on the rear of tractor. Did this work? I have often wondered.
Ralph
01-07-2002 07:36:45
 Re: Re: 3 point hitch for JD 60 in reply to Ralph, 01-06-2002 19:47:24
I forgot to mention; J D called this Traction Trol.
Richard
01-07-2002 19:33:56
 Re: Re: Re: 3 point hitch for JD 60 in reply to Ralph, 01-07-2002 07:36:45
Thanks guys for the info. Never heard about the traction trol! I just remember the 60 was the first tractor my Dad bought that had power steering--- I remember it was a great thumb saver! Thanks--Richard
