Flywheel Nuts on 39B
Brian
01-04-2002 12:27:56
I need a little help. I don't have the special socket/wrench combination to take off the flywheel on my 39B handcrank. Does anyone know a combination that will loosen the nuts so that I can get the flywheel off?
Thanks
ed b
01-04-2002 20:00:48
 Re: Flywheel Nuts on 39B in reply to Brian, 01-04-2002 12:27:56
i used a long socket extension and a universial for the socket on my 43 ed b
Brian
01-05-2002 15:41:44
 Re: Re: Flywheel Nuts on 39B in reply to ed b, 01-04-2002 20:00:48
Ed,
Thanks for the idea. I used a flexible head socket wrench and a deep socket. It worked!
Thanks Easydoesit, I was going to try some local two cylinder people next if it did not work.
ed b
01-05-2002 18:11:49
 Re: Re: Re: Flywheel Nuts on 39B in reply to Brian, 01-05-2002 15:41:44
glad it worked for you ed b
easydoesit
01-04-2002 13:23:19
Brian, You are not alone in this world. You probably have a tractor club near you. Find out who they are and join up. They probably have alot of JD guys who would like to loan you a wrench. I have one but unless you're near Tennessee the cost of mailing is probably high. Tractor people are some of the best.
