Clutch/belt pulley questions on 720
Kevin
01-03-2002 08:37:27
I have a 720d. When you ingage the clutch, the belt pulley slides outward about an inch. The clutch is real "grabby" also. I have had the pulley and clutch off. I can't see what would be worn. Any ideas would be appreciated.
Thanks
Kevin
mrm
01-05-2002 05:46:51
 Re: clutch/belt pulley questions on 720 in reply to Kevin , 01-03-2002 08:37:27
don't forget to look at the splines in the clutch drive disk and on the crank rh side it could be shot. Welcome to the wonderfull world of two-cyl
diesels,where they run no matter how bad they are
falling apart!!! Those two-cyl. diesels can pull
anything you hook to them including the pages of
your check book!!! Good Luck and have fun and try
to fix it right so many people just cob job.You
reap what you sow.
Donwisc
01-03-2002 19:37:06
Had the same problem on a previous 730 D where I had about 1/2 inch play. It would try to pop a wheely no mater how I feathered the clutch. The thrust washers behind the flywheel had to be replaced.
The current 730D I have has about 3/16 end play measured at the flywheel. Flywheel is a taperlock, and Im preparing to change thrust washers on this one too.
Try this check, tractor not running, shifter in neutral, engage clutch, measure end play at flywheel. should only be .004 thou when new
Good luck Don
Dave 2N
01-03-2002 14:39:07
Check with Clooney but based on the help he gave us with our 70, my first step would be to check to make sure that the fly wheel is tight.
ChuckW
01-03-2002 13:58:08
there is a thrust washer on the inner case...about 1/4" in width, suppose there is a possibility it is gone.
ChuckW
01-03-2002 11:08:38
sounds like your crankshaft is also moving, better check and make sure you flywheel is tight. Disengage clutch and if you can push the center towards the tractor then the flywheel is loose. Loosen up the clutch disc and tighten flywheel then readjust the disc.
Frank
01-03-2002 12:58:52
 Re: Re: clutch/belt pulley questions on 720 in reply to ChuckW, 01-03-2002 11:08:38
Wow ! If he's got that much endplay, and some of it is coming from the flywheel side, he might have damaged the thrust washers behind the cover behind the flywheel, also.
Frank 70D (Been there done that !)
Kevin
01-03-2002 18:55:11
 Re: Re: Re: clutch/belt pulley questions on 720 in reply to Frank, 01-03-2002 12:58:52
Flywheel is tight, Have had right side off. Crankshalf is tight. Movement is in the belt pulley assembley.
Clooney
01-04-2002 03:28:40
 Re: Re: Re: Re: clutch/belt pulley questions on 720 in reply to Kevin , 01-03-2002 18:55:11
~Kevin, depending on if you have an early or late 720 the pulley lateral movement is controlled by the sleeve operating fork stops. The early design is by shims at the pulley brake operating pin & the later is by stop bolts on the back of the operating sleeve fork. If your 1st reduction cover has little bolt on covers on the top & bottom it is the later design. In either case you can adjust the pulley end play to an acceptable level (probably somewhere around 3/16"-1/4") by either shimming or removing the little covers & adjusting the stop bolts.
~As for the grabby clutch, the pulley end play probably isn't helping it but probably is not the (entire)cause either. Make sure the lining(s) aren't bent, glazed or oil soaked, then check the 3 adjusting bolts for step wear where they go through the pulley holes (if found either replace the bolts or file the steps smooth), then make sure the double sided disks are installed so they are driven by the drive pins & not the adjustment bolts. ~If all the above doesn't make the clutch engage better then make sure you don't have excessive wear on the operating sleeve, toggles, dogs or the dog pivot pin holes in the pulley ears & dogs aren't wallowed out & extremely sloppy
buckeye al
01-03-2002 15:25:34
Agreed! The fiber thrust washer index tab HAS to be gone & spinning which will wear the timing gear cover prematurely. Time to bare both ends of the crank, possibly remove the timing gear cover & start setting things right before the flywheel goes bad too!
