JD A Unstyled to styled when?
steveii
01-02-2002 20:44:51
I would like to know when they started building the styled tractors JD A from the unstyled.
my tractor is #540063 is styled. no battery.
steveii
01-03-2002 19:35:39
 Re: JD A Unstyled to styled when? in reply to steveii, 01-02-2002 20:44:51
Yes my tractor has cast iron frame, Hand fly wheel start. six-speed transmission. it has been sitting in garage for years waiting to get parts, right now I am getting parts for it, dont have picture yet. I took over this tractor when I was age 13, dad was about to send it to junk yard I did't let him at last it's still there, he been saying to get way of it and I just let it sit.
Mike H
01-03-2002 17:52:37
The first styled 4 speed model A was 477000,built August 1,1938
Will P
01-03-2002 17:52:30
Are you looking for the unstyled tractors that where made styled? When Deere came out with the styled A on Aug. 1, 1938 as a 39 model. The unstyleds that where in stock where converted to styled. That batch is:
477500-477600
477900-477999
478200-478472
For a total of 472 unstled tractors that where made into styled.
Your tractor is a "war" 1944 tractor. You should have a cast iron frame on it.
Hope this is what you where looking for.
Will P
steveii
01-03-2002 19:45:00
 Re: Re: JD A Unstyled to styled when? in reply to Will P, 01-03-2002 17:52:30
Is the "war" build tractor rare? I am't sure if there are alot around. kind of looking.
Mark in Indiana
01-03-2002 10:33:22
1938 was the last year of the unstyled. They made the "A" two years styled with the 4-speed transmission and most of them were flywheel start although the electric-start was an option. Then 1941-1947 were the six-speed transmission with the electric-option known as the long hood or slant-dash. The early "A's" from 1939-1940 had the unstyled engine but were styled. Hope this helps! Mark
Richard
01-02-2002 22:09:31
Both JDman and Frank are close to right. How can that be?. The A and B were tested in styled sheet metal in mid April 1938. The A rolled off the assembly line as a styled tractor Aug 1 1938 as a 1939 model. The B a little later as it was recieving mechanical upgrades as the A didn't. If your A is a straight Model A, it should be a 41 model year. 1940 the cubic inch displacement was increased from 309 to 321. By 1941 the rubber tired model A's had two stick 6 speed transmissions. Hood lettering went from silk screen to black bordered decals. Electric start was an option until 1947.
jdman(MO)
01-02-2002 21:43:58
Frank is right the last un-styled A was 1938. Russ
Frank
01-02-2002 20:58:30
I think it was '39 ? I could be wrong there, but it was around then.
Frank
