3020 electrical power
Oaktree
01-02-2002 14:26:21
I have a 24v 3020 that I use to spray with.While spraying, the electic solinoids and the air compressor for the foamer draw 25 amps at 12v. I was thinking of adding 2nd 12v alternator and battery for this. The solinoids could be balanced between batteries but the compressor(15amps) will always be a problem. Any constructive thoughts?
BrokenWrench
01-03-2002 16:16:43
 Re: 3020 electrical power in reply to Oaktree, 01-02-2002 14:26:21
The easiest way would be to convert the tractor to 12V. By the time you fabricate an alt bracket, add the double groove balancer pulley, battery tray, wiring and switches you'll probably have the same amount of money in it as the conversion. Last one I did was about $650. plus batteries.
