Early-B Hydraulics
ryan
01-01-2002 09:54:20
I've got a question about the hydraulics. I bought my B running, but it didn't have any hydraulic oil. It has Power-Trol. I probably need to overhaul the whole system including the pump. Where is the Hydraulic Pump at? Any help you could give me on this is appreciated.
Ryan
01-02-2002 07:28:09
 Re: Early-B Hydraulics in reply to ryan, 01-01-2002 09:54:20
Ryan,
Your pump may be OK, just needs oil. I don't think you use hydraulic oil, just straight 30 weight motor oil. Some people suggest flushing it out with kerosene or diesel for a few minutes first.
(Please confirm this from another member of this board or from the JD manual for your tractor before you do this. I don't want to steer you wrong.) Anyway, that could save you a lot of work, unless you were going to do it anyway as part of a restoration.
gary
Bob Weber
01-01-2002 16:43:55
Ryan, the hydraulic pump is right under the cover where the PTO shaft goes into the back of the tractor.
