Jd 730 d
IHpuller
12-31-2001 17:42:10
i was considering buying a jd 730 d for cheap. owner says he hasnt tried to start it. it has tires pto hydrolic and 3 point. it is 1500. havent seen it yet. does this sound like a lemon tractor? i know all my ih diesels were real expensive to fix/rebuild. i would like to buy this tractor to fix and resell. it is also stuck in second gear. would any of you out there buy it? any comments on the tractor in genral or what to expect?? i would appreciate as many opionions as possible!! thanks for helping this ih guy out! derek
donwisc
12-31-2001 19:19:44
 Re: jd 730 d in reply to IHpuller, 12-31-2001 17:42:10
It should be a nobrainer. If you find its going to take too much to fix it you should be able to part it out and still make a buck.If its a original JD 3 pt it will bring over 600 and more if the top link is there.
Roy
01-01-2002 16:41:22
 Re: Re: jd 730 d in reply to donwisc, 12-31-2001 19:19:44
If you don't want it I'll take it!
Roy
01-01-2002 16:41:07
