G's with distributor as stock?
Kris
12-31-2001 11:39:31
I've seen pictures of G's with distributors on them and wondered if these were just on the very late ones? Can a tractor with a magneto be converted to have a coil and distributor? I believe I saw an old ad for a 1952 50 and it also had a magneto.Thinking maybe they changed to distributors in 1953?
Clooney
12-31-2001 13:38:42
 Re: G's with distributor as stock? in reply to Kris, 12-31-2001 11:39:31
~Kris, a Delco distributor was used on the "G" from s/n 46,501 up (late 1950). I am not sure if a dist. was standard & a mag was optional or a mag was a dealer only option.
~A distributor could easily be installed on an earlier "G" as long as it had a battery , if a coil, ignition s/w, & the proper wiring were installed. The drive lug length would also have to match the governor drive flange (I believe they were the same from about 1942 up).
