Front blade on M questions...
Billy T.
12-30-2001 18:22:11
I got the tractor and it came w/a front blade that wasn't on the tractor. It has two long pipes and appears as though it would hook up in the back somehow. How is this? How does it raisse and lower? thanks for any info.
Ralph
12-31-2001 07:50:10
 Re: Front blade on M questions... in reply to Billy T., 12-30-2001 18:22:11
Billy, The factory blade for the M was a M-32 or 34. The long pipes as you called them were angle iron with a flat plate on the back. The plate has a large hole in it and that goes over the pivot points of the drawbar. This is held apart by a angle bolted between them to hold them in place. There is a pully that goes on the pivot pipe of the front axle and one that goes on the left side of the drawbar. A cable then goes from the left lift arm by the seat through the pulleys and down to the blade for lifting.
Ralph
12-31-2001 07:48:17
Richard
12-30-2001 21:25:18
I can't give you specifics about a blade, but these tractors used special linkages to attach the implements. I searched for a power depth control for my MT to attach the plow. Finally found it at a supplier in Holyoke Colorado. Can't remember the name.
Jerry
12-31-2001 19:36:54
 Re: Re: Front blade on M questions... in reply to Richard, 12-30-2001 21:25:18
Does anyone have a digital photo they could send of the attachments for a front blade? Just "engineered" a new front mount blade for my 51 Cub, but would like to do the same for my 49 M....
