82 jd410 backhoe\loader trans hydro problem
George
12-29-2001 15:20:57
have a chance to buy an 82 (410) for $5500 i must decide by thursday 1\3\02 the owner thinks the trans pump is bad(shuttle shift)???it moves, but very slow otherwise looks to be in fair shape.any advise????? parts available???price???? i know nothing about these machines---- yet----thanks a bunch
Brokenwrench
12-29-2001 16:40:04
 Re: 82 jd410 backhoe\loader trans hydro problem in reply to George, 12-29-2001 15:20:57
George, if the rest of the hydraulic functions are OK then the trans. pump is good. The trans. pump feeds oil to the main pump in the front of the tractor, provides lube oil for the trans. and supplies charge oil pressure to the shuttle packs.If the rest of your functions are good then I would look for a shift valve problem, a sticky inching pedal valve (valve the clutch pedal hooks to) or bad sealing rings for the reverser clutches, or bad clutches. Does it move slowly in both foward and reverse? It could be as simple as a clogged trans. filter.(under the right of the trans. a round canister that bolts up to the trans. case, 3/4 inch socket will remove it) The price seems fair assuming the rest of the machine is in OK shape even with the sluggish reverser.
