4230 pto problem
John in Md.
12-27-2001 16:41:13
Is there an easy way to install snap rings on PTO carrier bearing in casting on lower shaft without pulling whole rockshaft off top of case?Or will rockshaft come off without pulling cab?
brent
01-01-2002 11:16:28
 Re: 4230 pto problem in reply to John in Md., 12-27-2001 16:41:13
you can get the rock shaft off by lifting the cab 3 or 4" be carefull fo the dip stick and draft linkage. from what i rember you shouldnt have to take it off. the first snapring you can squeeze the next after ,the bearing, a good screwdriver will work
Frank
12-27-2001 19:39:02
You should be able to take rock shaft offwithout removing cab. Remove rear cab mounts and jack up rear of cab about 3inches . This has worked for me on tractor without 3ph.
