730 power steering / Vent ??
Ben.So.Tex
12-27-2001 12:16:20
I have filled the power steering to the proper level,,Dose the power steering have a vent on it,,I can take the filler plug off while it is running/or off ((after warmed up)) and it has pressure in it..
Don
12-28-2001 07:36:09
 Re: 730 power steering / Vent ?? in reply to Ben.So.Tex, 12-27-2001 12:16:20
The pump seals are worn letting the pump suck air. It will eventualy start blowing oil out the vent hole. There is only one cure and it's not cheap. Hope this helps.Don
Steven M
12-27-2001 15:38:45
There is a vent plug in the center of the top of the dip stick. If there is an accumulation of dirt on the plug,remove dirt with compressed air or rinse in solvent. The porous plug allows breathing of the power steering system.
