JD 420 sway control
SteveG
12-26-2001 20:22:17
I'm familiar with the sway control on 3-point of ford 8n, etc., and sway blocks on larger 2-cyls, what was/is used for the smaller JD's to control sway of 3-point? thanks
Fred Mills
12-27-2001 10:42:19
 Re: JD 420 sway control in reply to SteveG, 12-26-2001 20:22:17
Steve, on my JD 40 Standard, there is a yoke that fits onto the tractor under the middle(top) link and into a channel on the implement. I cut one down that came from a 420. This is the sway control required for the rear cultivator for example. The chains and blocks allow too much sway to track the rear wheels. E-mail me and I'll send you a sketch if you like. I only paid $10.00 for mine. A dealer in Pa. wanted #125.00. They are hard to find in some areas.
MERRILL
12-26-2001 22:02:44
STEVE, I CHECK MY MANUAL THE 420I,W,&T ARE THE SAME THE 420H,S,U,V,&C ARE SLIGHTLY DIFFERENT,WHICH DO YOU HAVE?
MERRILL
12-26-2001 21:44:03
STEVE, ON YOUR DRAFT LINKS BOTH SIDES YOU SHOULD HAVE SWAY CHAINS WITH BLOCKS WHICH ARE INSERTED ALONG SIDE YOUR DRAWBAR. THAT IS FOR A 420W.
