John Deere 60....
BushogPapa
12-26-2001 12:34:50
I need some information....
Will a 60 pull as much as a 620, if the 60 has increased compression-maybe an overbore of +.125?? Also--does anyone know if the 620 power-trol will mount on the 60 rear end.?-( for depth and load control )..? I need these answers, before I start tearing down the 60--it is all-fuel, and is not up to the work I need it to do... I think the 60 should be able to put out the needed power..... ..what do YOU think..????? Thanks.....!!!!! Ron. BushogPapa.
Mike Aylward
12-26-2001 16:31:33
 Re: John Deere 60.... in reply to BushogPapa, 12-26-2001 12:34:50
A 60 can be "enhanced" to keep up with a 620 just fine. A set of higher compression aluminum pistons and a good valve job and perhaps a little taken off the head will wake up your tractor very nicely. A good clean carburetor, good ignition system and good fuel will make your 60 keep up with, or maybe even embarass a 620. I also set the governor to carburetor rod slightly shorter than the recommended "half a hole short". A full hole short makes the tractor much more throttle responsive and will not make the tractor surge, and will lay into the load much better than the stock setting. I wouldn't worry about going .125" over unless your block needs it to clean up. With all of this work done 50 h.p. is not out of the question, which would likely be about 20 h.p. more than you have now. Everything needs to be "right", but shouldn't it be anyway? Hope this helps. Mike
