Coils - plus and minus. Question.
DaChew
12-01-2003 12:24:38
I hadn't noticed when I bought my 3010 gas that the coil was connected backwards. In other words, the + post was connected to the negative lead and the - post was connected to the positive lead. The tractor ran fine though, like a lot of 3010s, tended to foul plugs quickly. I figured this out while running through the tractor with a multimeter because I found the positive ground system interesting. When I got to the coil I noticed that my tech manual wiring diagram showed one thing while my tractor wiring showed the opposite. I switched the leads to what the diagram showed and the tractor started right up. My question is: Why should it matter? Why would the coil have a plus and a minus post other than to show that you need both for it to work?
Duane Larson
12-01-2003 14:57:24
 Re: Coils - plus and minus. Question. in reply to DaChew, 12-01-2003 12:24:38
DaChew,
The reason it matters is related to spark plug operation. If the coil is connected properly the center electrode of the spark plug is negative relative to the tractor body. This is best because the center electrode of the plug is hotter (temperature-wise) than the ground strap (the spark occurs between the center electrode and the ground strap), and physics tells us that electrons flow from - to +, and hot bodies emit more electrons than cold bodies. So, if the hot center electrode is -, it emits more electrons which should result in a better spark. The alternative if the coil is hooked up wrong is emission of electrons from the cold ground strap to the hot center electrode. Spark Plug design manuals are adamant about this point - the center electrode is designed to be negative.
A rule of thumb is if the battery has the + terminal grounded, the + terminal of the coil should be hooked to the distributor, and vice versa. However, there are some simple tests to verify that the center electrode is negative, and I can provide them if you are interested.
John T
12-01-2003 19:15:01
 Re: Re: Coils - plus and minus. Question. in reply to Duane Larson, 12-01-2003 14:57:24
Glad to see the perspectives of a good physics man here Duane, I think you and I have discussed this before. Your point is similar to how in vacuum tubes they heat the cathode to emit electrons off it to the plate. They emit and are discharged best best from a hotter cathode to a relatively cooler plate anode, same as your spark plug analogy. In my old Purdue University EE days (BSEE 1969) they taught CONVENTIONAL current was + to - while electron current was - to +. Great discussion John T
Allan
12-01-2003 17:12:54
Duane,
You said: "and physics tells us that electrons flow from - to +, and hot bodies emit more electrons than cold bodies".
You are a smart one, Charlie Brown. Not many people know this little tid bit. I've known electronics instructors who can't get this one straight in their head and insist that electron flow is from positive to negative. :>)
Nice to see it posted here. :>)
Regards,
Allan
ron in MN
12-01-2003 17:55:46
 Re: Re: Re: Coils - plus and minus. Question. in reply to Allan, 12-01-2003 17:12:54
I think it was at the beginning of the "solid state" era that electronics instructors began using the convention of 'current flow' from positive to negative, but they probably didn't emphasize that 'electron flow' was still going from negative to positive. It's probably always easier to think in terms of which 'convention' you learned first! I learned 'electron flow' convention first as a Navy technician, then later learned the 'current flow' convention while studying to become an electronics engineer.
Allan
12-01-2003 18:15:59
 Re: Re: Re: Re: Coils - plus and minus. Question. in reply to ron in MN, 12-01-2003 17:55:46
Ron,
You nailed it like a hammer and I feel the same way.
My trouble is, my little pee-brain can't understand how some of these guys can look at a schematic and justify that electron crossing the gate backwards. :>(
But like you say, it is probably how they were taught, how they understand it and at the end of the day, it doesn't really matter how one interrupts it, as long as they can visualize the water flowing in that garden hose, I guess. :>)
Thanks for the hollar,
Allan
Clooney
12-01-2003 14:50:54
DaChew, on all [original] Deere coil's the same coil terminal should go to ground on the coil as the battery has going to ground.. The coil gets it's ground through the points in the distributor.. So on a positive ground system the positive terminal on the coil should go to the points..
~Coil's are polarity sensitive & produce a secondary spark based on the input polarity.. The reason that makes a difference is it is much easier for a spark to jump from the spark plug's center electrode to the side electrode than to jump from the side electrode to the center electrode..
~On systems with a low output coil the difference can be enough to cause plug fouling or other small problems.. On a high output coil system it makes almost no difference & a lot of the new automobiles fire every other spark plug at reversed polarity without any problems..
~Your system should have a resistor in the wire to the coil so it uses a 6 volt type coil & that should be installed with the same coil's terminal [+ or -] going to the distributor as the battery has grounded.....
[email protected]
DaChew
12-03-2003 11:23:27
 Re: Re: Coils - plus and minus. Question. in reply to Clooney , 12-01-2003 14:50:54
That's interesting. I ordered a new coil from this very site. What I got was a coil that says right on it "for 12 volt systems with external resistor". Suppose that's actually a 6 volt coil and they just labeled it that way so as not to confuse pedestrians such as myself?
Clooney
12-03-2003 13:58:24
 Re: Re: Re: Coils - plus and minus. Question. in reply to DaChew, 12-03-2003 11:23:27
DaChew, you say...What I got was a coil that says right on it "What I got was a coil that says right on it "for 12 volt systems with external resistor". Suppose that's actually a 6 volt coil ".....>>Probably is a 6 volt coil.. most of the originals were, then later the coils design changed slightly but still operated at 6-8 volts..
jdemaris
12-01-2003 14:20:40
I don't have much to say on the polarity issue that hasn't been said already. Without being too erudite or scientific, you can get 10-30% less POTENTIAL output if hooked up wrong. In the real world, you may never notice the difference. I worked for a JD dealer when Deere was selling retrofit kits for the igniton on all the 10 series tractors. Basically it came with an improved ignition switch, ballast resistor and bypass. Never understood Deere's version of the bypass though, since most of the tractors had Delco starters and solenoids, and the solenoids already have a resistor bypass built into them, i.e. the "R" terminal.
John T
12-01-2003 14:02:08
Dear Da, this subject has been discussed quite a bit here over the years, and there are a few things I can say for sure about the subject.
1) If a coil has no internal ballast whatsoever, such as when JD used a 6 volt coil on a 12 volt system and used the external ballast resistor, it should be wired acordingly to match the tractors ground system. I.e., if the tractor is pos ground (its pos. post grounded) wire the coils lil primary terminals - from the switched (ballasted) source and + to the distributor where its gets a ground when the points are closed. Conversely, if its a neg grnd system, the coils - is wired to the distributor where its grounded via closed points and the + terminal receives switched power. On such, the ballast is always wired right after the switch and ahead of the coil, so its NOT located between the coils output and ignition points/condensor inside the distributor.
2) Coils are labeled according to the way they are physically wired and connected internally. When current passes through a wire, the magnetic flux generated has a N and S polarity dependant upon the direction of current flow (the old right hand screw rule). The winding orientations and current directions for the primary and secondary windings are designed to achieve maximum mutual inductive coupling and efficiency and to minimize any losses; it wants to transfer as much energy as possible from the low voltage primary to the high voltage secondary and minimize losses. Its true a coil will still work if not wired as labeled, but its better in my opinion (regardles how measurable) if wired correctly. Sorry, I have no data or specs or curves on any voltage differences or efficieny regardign correct versus incorrect wiring as labeled, but they still work either way although correct is preferred.
3) All the 2 cylinder JD's were originally pos ground and even the new generation until they switched from generators to alternators I believe.
4) A few questions: Is yours pos or neg ground??? Does it have an external ballast resistor?? or a resistive wire ahead of the coil?? Is the coil a 6 or 12 volt unit???
Good topic for discussion
Best Wishes n God Bless ya
John T Nordhoff [email protected]
DaChew
12-03-2003 11:18:05
 Re: Re: Coils - plus and minus. Question. in reply to John T, 12-01-2003 14:02:08
I believe that you are probably correct that it is best to wire accordingly though the coil will work wired either way. My guess is that there is some (probably unmeasurable with my cheap Radio Shack multimeter) difference in output to the distributor but that it may not functionally make a difference. At least in the short term: I hadn't considered whether longterm usage wired backwards may lead to premature failure of the coil.
My 3010 is positive ground 12volt system. The wiring diagram shows a resistor at the key switch. I've confirmed the presence of some type of resistor using my multimeter but I haven't looked to actually see it. I figure as long as it's running good there's no need to disturb the very old wiring.
old
12-01-2003 12:38:45
Well like most things DC they work better if hooked up the right way and with a coil you get a better spark when its hooked you the right way. It may even help with the fouled plugs.
