Brake water leak
philip Covalesk
12-24-2001 08:29:30
Brake valve blocks that are located on the side of the transmission case are not sealed properly to keep out water. Water can contaminate the brakes and transmission oil. Seal the area between the these two parts (above the gasket and after installation of unit) with grease or better yet, use a waxy petroleum product called Techtyl 506G. Also, the caps on top of the Brake Valve Block will retain water and leak. Seal these also.
