4020 3pt
Russell Montgom
12-23-2001 17:06:52
I have a 4020 and i went to pull up the 3 point lever and the 3 point dos not come up. The transmission fluid is fine and at the correct level what could it be thanks for the help, Russell
Thurlow
12-23-2001 17:38:30
 Re: 4020 3pt in reply to Russell Montgomery, 12-23-2001 17:06:52
Russell, first thing to check is to see if cable is actually moving rockshaft control arm. This is under the cover at right rear of tractor just above your remote control outlets. Broken cable or lost e-clip is the simplest thing it could be. If arm is indeed moving, then cam follower is probably off track inside control valve housing. According to service manual, this can be put back on track through access plug in rear of tractor (remove with 1/2 breaker bar). I've not had much luck doing this, usually wind up removing control valve housing. This terminology may not be exactly right, don't have manual here. Post back, someone on board can walk you through procedure.
