Pulley oil leak problems
Bguy
12-22-2001 16:02:46
I have read thru the archives but I didn't see any direct answer to this so I'm asking about it again. I have gone thru the clutch/pulley on my 35 B and it works great except that after awhile it will start to leak oil around the inside of the pulley (next to the dust cover). I pulled the clutch and pulley this evening to see if there was any apparent reason for this and I couldn't see any. Everything looked as it should. Except that the oil is running down the inside of the dust cover and dripping onto the inside of the pulley and is then slung to the outside. The crank bearing shims/spacers are down against the crank and the drain hole to the crankcase is open. Any ideas on how to fix or things to look for would be greatly appreciated.
Fpull
12-22-2001 21:05:51
 Re: Pulley oil leak problems in reply to Bguy, 12-22-2001 16:02:46
Check and make sure you do not have too much oil in crank case. just a little over full will make them throw it out. Also make sure your oil is not diluted.
Tom
12-22-2001 17:13:23
Same thing happened to me on a 48 B. Ended up being excesive blow by into the crankcase. Pull the oil fill cap after she warms up and see if you have exhaust gas coming out. Pulling this cap also relieved the pressure and eliminated the oil leak..Albeit temporarily.
Bguy
12-22-2001 18:19:49
 Re: Re: Pulley oil leak problems in reply to Tom, 12-22-2001 17:13:23
Tom, I don't know, this B has new rings and good compression. I guess I could take out the oil fill "filter" on the breather cap. I wondered if this might be clogged? I'll check it out, Thanks.
Clooney
12-22-2001 16:58:47
Bguy, that occurrence is kind of normal on the early un-styled tractors. Are you sure it isn't running out between the clutch collar & pulley then running down the inside of the pulley & ending up on the dust shield? The other reason is if the drain behind the dust shield is covered or full of sealer so the drain back channel in the dust shield is filling with oil then overflowing & running down the outside of the dust shield. If it is running between the collar & pulley (there isn't a seal there) due to wear about all you can do is not idle the tractor with the pulley dis-engaged for long & live with the leak or find a way to get a seal between the collar & the pulley spigot that it rides on. Some of the later tractors use a felt seal in that area. Make sure the crank end play isn't excessive as the crank moving in & out can add to the oil leaking problem. If you are using new super slick or multi-weight oil change to a heavier single weight oil as the multi-weights tend to leak out of almost everywhere.
Bguy
12-22-2001 18:14:37
 Re: Re: Pulley oil leak problems in reply to Clooney, 12-22-2001 16:58:47
Clooney, I have had the dust shield and all off and cleaned it up good and replaced all of the gaskets and etc so the dust shield drain is open so the oil can drain out the bottom of the dust shield (and then run down the outside of the crankcase). But for some reason oil is getting on the part of the dust shield that faces the inside of the pully. I wonder if the felt seal from a later model would fit this one? That would solve the problem I guess. Do you have a part number on the felt piece? Thanks.
Clooney
12-22-2001 18:45:18
 Re: Re: Re: Pulley oil leak problems in reply to Bguy, 12-22-2001 18:14:37
Bguy, the closest model that used a seal on the clutch sleeve was the 620, the 520 didn't even use one. If you want to try something in your "B" you will probably have to make it or try an "O" ring of some sorts. How loose is the sleeve on the pulley? Is the drive gear pressed all the way on? You might try to pack some heavy grease between the sleeve & the pulley spigot just to see if that will stop the oil leak temporarily. Have you looked the dust shield over carefully for holes & cracks?
Bguy
12-22-2001 19:40:49
 Re: Re: Re: Re: Pulley oil leak problems in reply to Clooney, 12-22-2001 18:45:18
Clooney, The dust shield is OK, I replaced the one that was on there because it had a hole worn in it. The sleeve seems to fit fairly good and as far as I can tell the drive gear is all the way on. I am going to look at making a felt or using an O ring and check the crank case vent as suggested in the other post. Thanks.
Clooney
12-22-2001 19:50:32
 Re: Re: Re: Re: Re: Pulley oil leak problems in reply to Bguy, 12-22-2001 19:40:49
Bguy, make sure your oil pressure isn't too high also as oil will really pour out of the R/H main bearing if it is.
Bguy
12-22-2001 22:16:53
 Re: Re: Re: Re: Re: Re: Pulley oil leak problems in reply to Clooney, 12-22-2001 19:50:32
Clooney, the oil pressure may be a little on the high side according to the gauge. It stays right at the H after it's warmed up good and at a fast idle. I am using straight 30W oil. Think I should back off this pressure a tad?
Clooney
12-23-2001 05:38:26
 Re: Re: Re: Re: Re: Re: Re: Pulley oil leak problems in reply to Bguy, 12-22-2001 22:16:53
Bguy, you might want to put a good gauge (0-25 lbs resolution) & set it to 15 lbs hot. "H" on your gauge might only be 15 lbs now. One other thing to look at, are the little drain holes open in the operating sleeve? At least I believe the early B has the drain holes drilled in the gear side of the sleeve? You might want to bolt the "clutch driver only" back on & then start the tractor & look inside with a light & see how much oil is coming from the R/H main bearing or blowing through the drain & main bearing housing with the engine running. If you can see excessive oil maybe you can then figure out how to handle it better.
Bguy
12-23-2001 07:13:45
 Re: Re: Re: Re: Re: Re: Re: Re: Pulley oil leak problems in reply to Clooney, 12-23-2001 05:38:26
"You might want to bolt the "clutch driver only" back on & then start the tractor & look inside with a light & see how much oil is coming from the R/H main bearing or blowing through the drain & main bearing housing with the engine running."
Good Idea!!
