Governor Repairs 1945 A
Robert
12-01-2003 09:56:57
After running this tractor for awhile now, doing different chores (mowing, disking), I've pretty well determined that the governor is not working as designed.
I can get things done by using the throttle, but this gets to be a pain after awhile, constantly having to throttle up or down as conditions change.
Now, for the question. How much of the governor can be accessed from the outside to do repairs, or should I just plan on taking the darn thing off, and working on it like that?
Thanks for any and all help/suggestions!
Clooney
12-01-2003 13:33:02
 Re: Governor Repairs 1945 A in reply to Robert, 12-01-2003 09:56:57
Robert, Duane & Frank gave you some good advice below, so start there..
~While you are there & looking,,, look at the top of the carb where the throttle rod attaches & MAKE SURE the cotter pin isn't bent so it is hanging up on the carb casting [a common problem]...Then operate the linkage by hand [engine not running] & check for the linkage rubbing or contacting the fuel tank or tank mounts, or anything else.. Then look closely at the big leaf spring on top or the governor shaft for signs of cracking or being bent incorrectly...
~One more thing.. Make sure the leaf spring is installed correctly & bending away from the governor lever & not into it.. That big spring is what gives you wide open throttle [does it?] & the governor's job is to try & keep that from happening [can it?]..
[email protected]
Robert
12-01-2003 14:10:53
 Re: Re: Governor Repairs 1945 A in reply to Clooney , 12-01-2003 13:33:02
Clooney, like I said in my second post, the "problem" may well lie between the operator's ears. Everything APPEARS to be as others have suggested. The linkage is adjusted so that there is spring preload on the throttle shaft/carburetor, no binding in the butterfly, throttle spring isn't cracked, etc.
My concern, is that I can't seem to find a throttle position that will satisfy a very wide variety of load conditions, I seem to be either too fast or not fast enough for conditions, and either the engine is running near wide open, or nearly lugging, and the governor arm doesn't seem to move at all. If conditions don't change, then the selected throttle position is just fine, but if the load changes (heavier mowing, going up an incline; or the load changes in the other direction, going down hill, lighter mowing, etc) then I find myself "tweaking" the throttle.
What am I missing in this?
Duane Larson
12-01-2003 18:55:17
 Re: Re: Re: Governor Repairs 1945 A in reply to Robert, 12-01-2003 14:10:53
Robert,
Sounds from your additional information that you may well indeed have a governor problem. One possible problem is the forks (which are operated by motion of the the weights as the rpm changes) have developed a flat spot (usually due to the engine running at a fixed speed for long periods of time). As the governor operates, it tends to hang at speeds where the flat parts of the forks are pushing on the thrust bearing. This can be solved by re-grinding the forks so they have a smooth curve again.
Several other problems could be happening - worn bearings, loose weights, etc.
But, I would still do the tests suggested earlier since they are easy and will pin down the problem to the governor.
Let us know what you find--
MAD DUC
12-02-2003 03:19:45
 Re: Re: Re: Re: Governor Repairs 1945 A in reply to Duane Larson, 12-01-2003 18:55:17
Duane,how do you go about re-grinding the arms? I have mine all apart and noticed the very small flat spots, but it did not run bad. This tractor is used mostly for pulls(fun not dead serious) and some real work. What about removing material from the weights to make them lighter? Any benefit?
Duane Larson
12-02-2003 06:40:26
 Re: Re: Re: Re: Re: Governor Repairs 1945 A in reply to MAD DUC, 12-02-2003 03:19:45
MAD DUC,
The arms are hardened, so I use a Dremel tool to remove metal and reshape the contact points. A smooth radius on the arms where they touch the thrust bearing is the goal. Don't worry about effects of removing metal - that is taken up as the governor linkage is adjusted.
You might also check the condition of the pins which hold the weights - if the weights are loose in directions other than the in-out motion the pins need to be replaced. I redrill the holes in the gear casting to 5/16, and use the Dremel tool with a cutting stone to enlarge the weight arm holes, and fashion a pin from water-hardened 5/16 drill rod.
I'm not a puller, so can't comment on pulling effects of removing weight from the weights. However, the effect will be the weight will swing out further at a given rpm if weight is removed. When the tractor is in a hard pull, the governor has little effect as the butterfly is against the carburetor stop pin.
Duane Larson
12-01-2003 10:26:21
Robert,
One test you might try before going into the governor - remove the cotter pin holding the governor rod to the carburetor butterfly. Start the tractor, remove the governor rod from the butterfly and control the engine speed by rotating the butterfly by hand while holding onto the governor rod with the other hand. If the governor action is smooth as the engine speed is varied, the governor is likely working as it should and you might look elsewhere for a problem. However, if the governor rod does not move smoothly, your assumption was correct and the governor likely needs work.
Most everything can be done by removing the governor shaft, which includes the weights and essentially everything of importance to proper governor functioning. Exceptions would be a bad fanshaft gear (which is driven by a gear on the governor shaft), and a bad bearing housing on the end of the governor which drives the magneto. It is relatively easy to remove the governor shaft - much easier than removing the whole governor. To ensure proper timing when putting the shaft back in there are two things you can do - 1) remove the magneto and rotate the engine so the left-hand-impulse mark on the flywheel is lined up with the mark on the transmission case - at that time the slot in the end of the governor shaft which drives the magneto should be horizontal. When you put it back together, line it up like above and the (magneto) timing will be fine. 2) you can try to identify matching marks on the governor gear and the driving gear on the camshaft, but that is usually not so easy to do. Or, you can make your own timing marks before you remove the governor shaft.
Robert's Carburetor Repair has a nice video covering governor repair. www.robertscarbrepair.com
F-I-T
12-01-2003 10:20:02
Robert:
Other than two bearings, the majority of governor problems come from misadjustments.
Try this:
Unhook the governor to carburetor rod. standing beside the tractor, run the engine and use your left hand to operate the carburetor rod. Take your right hand and see that the governor is moving freely, and trying to chase the engine. If so, shut things down, and with the throttle wide open, and the carburetor butterfly held wide open, the rod whould be 1/2 to 1 hole short of connecting. If not adjust the link until it is. Then pull against the governor leaf spring and hook it up. This puts some preload tension in the carb to governor linkage. This might be all you need to do, unless you have some other mechanical problem or noise you haven't mentioned.
Frank
Robert
12-01-2003 13:12:14
 Re: Re: Governor Repairs 1945 A in reply to F-I-T, 12-01-2003 10:20:02
Thanks for the advice. I'll check it out and perform the tests for adjustment as you've suggested, although I'm pretty sure it's adjusted as you've described, it won't hurt to recheck.
My observation (that the governor isn't working) comes from physically looking over the side while it's running, and seeing that the throttle is not far from an "off idle" position (under a load---6 foot mower), even while the tractor is slowing down (laboring), and then, when I give it a bit more throttle, the tractor picks up speed/PTO rpm, only to find that at the next flat area, the rpm's are too high, whereby I throttle back, only to repeat the steps at the next little rise.
Maybe that's normal for this type governor---this is my first and only two cylinder or any tractor, for that matter, but my understanding of other governor operation is that once the throttle is "set", the rpm should stay more or less the same, and not go up and down with the amount of load....
I'm open to suggestions, and not necessarily looking to fix something that's not "broke"....
It might be like a lot of things around my plant---- the problem is between "the operator's ears" ... LOL
