John Deere 755
Chuck
12-21-2001 20:07:57
Am doing some work on a John Deere 755, changed filters, oil. Engine wants to start but won't charge into action. Any suggestions. Haven't tried starting fluid, don't think is recommended.
Clooney
12-22-2001 04:55:45
 Re: John Deere 755 in reply to Chuck, 12-21-2001 20:07:57
Chuck, Henry J. has you pointed in the right direction, if you have tried to start it you might have air as far as the injector pump & will probably need to bleed the little inlet fitting at the injector pump also (same type of little hex screw). With the ignition s/w in the run position & the fuel pump running open the bleed screws until clean fuel comes out.
Henry J
12-21-2001 20:17:35
You need to bleed the fuel system. It sounds like the engine isn't getting enough fuel in all the injectors. There are 2 bleed screws above the filter. Loosen them and turn key switch to first position . Tighten screws when fuel flows free of bubbles.
