Clutch on a 35 jd B
Bill Morath
12-20-2001 15:58:49
how tight should the crank shaft nut be when you instal the clutch drive? If I tighten it as tight as I can then the clutch will not release. I have noticed on some tractors they but shims on the crankshaft that the drive attaches to , maybe I need to shim this since it is tapered. Can some one help. Thanks Bill
KHH
12-21-2001 15:14:39
 Re: clutch on a 35 jd B in reply to Bill Morath, 12-20-2001 15:58:49
I had the same problem with my 45B. I cleaned the crank and driver real good with break clean then put JB Weld on the crank and driver spline. I then tightened the driver on the crank and then loosened the nut 1 turn. Then used the driver pulling bolts to pull the driver out to the nut. Put a lightbulb on it to keep it warm for a couple days. I didn't really expect it to last very long but that was 2 years ago and it is still solid. I don't work it hard but use it to haul a little wood and plow the garden and such. It worked for me.
John Henry
12-21-2001 07:15:09
Had that problem on my 530. Seems the clutch drive had shucked on the cranhshaft and worn the tapered splines. That allowed the drive disc to stay engaged. I`m figuring that your B and my 530 are sorta similar. To test I shimmed the tapered splines with .002 shimstock and it worked great. That way you can torque up that nut to whatever spec it requires. The jury is still deliberating as to whether this can be a permanent fix or you need further repair/replacement. Ifn I`m wrong I hope someone will correct me. Perhaps Mr. Clooney will shed some light here.
