AMP meter reads 20
James
12-20-2001 12:39:59
I just bought a 50 that has an altenator on it. The amp meter read 20(pegs to the right side of the meter) The battery does not get hot. Is this ok?
Clooney
12-20-2001 12:49:52
 Re: AMP meter reads 20 in reply to James, 12-20-2001 12:39:59
James, probably nothing to worry about, most alternators are capable of putting out way more than the stock generator & 20 amps is probably still way less than the alternator is capable of. If it stays at 20+ amps after the tractor has run for over an hour you either have a bad battery or the alternator is wired wrong. It should drop back to a reasonable amount 5-10 amps after the tractor has run long enough to bring the battery up to full charge. If it doesn't drop back after you run it a while post back.
