4010 pulling tractor
Grimbo
12-18-2001 10:17:22
I am seriously thinking/want to build a 4010 pulling tractor. I want to pull "Stock" the first few years and maybe then drop in a 466 block with a p-pump and really have some fun. Right now I would like to build up the stock motor to be very competeive. What head do you reccomend, intake/exhaust manifold, and other little things that could help. Any good recipes? You can email me if you like
PS. Do you think the officails would be able to tell a 382/404 from a 466 block? Just throughing around some ideas...
Thanks
John Deeres Rule!
Phil
12-18-2001 11:21:27
 Re: 4010 pulling tractor in reply to Grimbo, 12-18-2001 10:17:22
Good Luck with your project - I've pulled Deere tractors for quite some time & the biggest, most important area to concentrate on with these tractors is cylinder head work.....One of the main problems is that Deere had their intake and exhaust on the same side of the head, making it very difficult to really work those ports to any significant degree, limiting power potential. Getting those heads to breathe is the most important thing you can do....Reground cams are also of significant help, allowing you to 'use' all of the head work. Once outside of classes that require stock head castings, there are aftermarket heads that dump on opposite sides....
