530 Hard Start
DarrylMO
12-18-2001 05:29:51
My 530 will start fine with the throttle set all the way back, at an idle. If I try to advance the throttle it dies. Once the tractor runs about a half a minute or so, the throttle can be advanced and it will run fine all day. Any ideas? Anyone else seen this?
Bob K
12-18-2001 05:43:29
 Re: 530 Hard Start in reply to DarrylMO, 12-18-2001 05:29:51
I had a similar situation with my 50 a few years back except that I couldn't get it to run faster than very low idle even after it warmed up. After several days of frustration, I decided to have the distributor rebuilt (new coil) and I never had any more trouble. It could be that the spark is so weak, it won't ignite the fuel at higher manifold pressures until the cylinders warm up.
Chuck
12-18-2001 16:19:23
 Re: Re: 530 Hard Start in reply to Bob K, 12-18-2001 05:43:29
rather than spending a lot of money on distributor rebuild, try adding electronic ignition. I've solved this problem on 5 tractors...genessee electronics is the place to look. about $110 for parts.
