John Deere 4320 Diesel
Gerrit Venema
12-18-2001 00:06:35
Is there anyone who can tell me why the 20-series diesel tractors are difficult to start. I am working now and then as a mechanic by a man who imports now and then some of this tractors. But they all start bad. First we take of the startermotor for repair, using new batteries. When starting, there is a lot of smoke out of the muffler which means he gets enough fuel, but don,t fire up. Is this normal for these tractors?
When they are running, they run very well without problems.
woman
10-06-2004 12:05:00
 Re: John Deere 4320 Diesel in reply to Gerrit Venema, 12-18-2001 00:06:35
It is very normal for a john deere 4320 to start hard year round. Part of it is from the motor that is in them and the intector pump is usually never the problem. I think it is just the motor after it gets about 3000 hours put on the motor.
Bob
12-18-2001 23:24:08
I just finished working on the starting system of my 4320. These tractors are cold blooded by nature. If the engine is in fairly good shape(enough compression to start well} The next thing you have to do is to get the starter to spin it fast enough to start. This is a big problem with the 4320.We have had this one since new and it never has started well until we got away from the factory batterys and installed a pair of group 31 12 volt with new heavy duty cables and went through the starter completely. This tractor will start now, better than our late model 4430.
Brokenwrench
12-18-2001 16:30:20
If you are using 20 series tractors remember they are at least thirty years old. They are very possibly showing their age. If the engines are in good condition they should start unassisted down to 20 degrees F. (12 degrees cel.) With any diesel,compression and proper injection timing are crucial. Check the pump timing, and if this is within spec. check the compression. Deere has made some changes in piston design (top ring closer to the top of the piston) to aid starting and for emission purposes. If you do overhaul the engine have the cyl. head rebuilt. The last 6 or 7 that I have done have required all new valves and seats, the machine shop attributes this to the low sulfer fuel we use here. Have the machine shop set the valves in the head to deere,s spec. this greatly inproves starting. Good luck.
Nutz
12-18-2001 19:37:12
 Re: Re: John Deere 4320 Diesel in reply to Brokenwrench, 12-18-2001 16:30:20
I've ran into the problem of having the holes in the injector tips not pointing in the right direction. If the tip is turned wrong when installed in the injector you will have fuel being injected at the valves insted of in the crater of the piston. This will cause harder starts and excessive white smoke at idle
