LP REGULATOR on 730
Ben.So.Tex
12-17-2001 17:10:08
I just rebuilt the regulator on my 730 LP..I have gas getting to the regulator but not coming out, the tractor will not start, I replaced all the parts..HELP.. Thanks Ben
Tom in Mo.
12-17-2001 19:14:53
 Re: LP REGULATOR on 730 in reply to Ben.So.Tex, 12-17-2001 17:10:08
In the rebuild kit there is included a piece of hardboard that is a gauge for adjusting the low pressure lever. They all need an initial adjustment due to using the same lever for various convertors.
If the gauge is already thrown out, check the service manual for correct lever height. Probably, 5/16 below surface level of convertor housing.
BEN.So.Tex
12-18-2001 03:27:41
 Re: Re: LP REGULATOR on 730 in reply to Tom in Mo., 12-17-2001 19:14:53
THANKS Tom, I think you hit the nail on the head. I got a manuel from a friend of mind last night and it shows to have this clearance, which I did not check for,, So I will pull it off and check for the 5/16 clearance
