How is the sediment bowl removed on a 440 Industrial Loader?
Terry A. Jenkin
12-15-2001 14:05:43
Does it screw off or doew it pry off.
It has been on so long that it is stuck and I don't want to take a chance of breaking it.
charles ethridge
12-17-2001 19:39:50
 Re: How is the sediment bowl removed on a 440 Industrial Loader? in reply to Terry A. Jenkins, 12-15-2001 14:05:43
terry, it screws off, on mine ,a gas engine,turn the small wheel on the bottom of the wire clamp clock-wise , try spraying with good pentration oil, or try to lift the wire clamp up and over it*s lock indention on the top of the housing, if you break it, it is the same as breaking a mirror!
also the gasket will probley have the glass bowl stuck, so after you get the clamp loose you still have to be careful and may have to tap the bowl gently with a small rubber mallet,be careful!
