52 B Governor Removal/lubrication
Frank, Tx
12-14-2001 10:26:56
Am I correct, there is no oil supply line to be disconnected when removing the governor on a late model B ? That is, I just reomve the governor attaching bolts and lift it off (hood, gas tank and fanshaft have already been removed). If this is correct, how is the governor lubricated ? Thanks, Frank, Tx.
ryan
12-14-2001 15:36:31
 Re: 52 B Governor Removal/lubrication in reply to Frank, Tx, 12-14-2001 10:26:56
Frank,
Your B should have a line going up from the oil pump to the governor. I removed the top nut then lifted the governor off. The oil line is kinda a pain to take off.
Good luck,
Ryan
