Hard starting
DW
12-13-2001 17:30:29
My model B has a good spark if I use a jumper wire from the mag or plug wire to the frame. About a 1/2 inch long. The spark at the plug looks weak. Not a nice fat hot spark. I have replaced the points, rotor,condenser and cap. Whats next, the coil? I am using autolite 386 plugs. The compression is running 90 psi on both cylinders. I do not know if that is ok or not. Any suggestions?
khh
12-13-2001 17:58:41
 Re: Hard starting in reply to DW, 12-13-2001 17:30:29
Clean the plugs good, check the gap, then draw paper thru the contacts. This will remove the last of the nonconductive depoaits. The paper from the plug box works good. This might help.
Clooney
12-13-2001 17:43:30
DW, make sure you are using solid core plug wires & not automotive TVRS resistor wires, a 2 cylinder ignition doesn't have a high enough output to use resistor wires. If your ignition is producing a 1/2" spark it must have a good coil.
