G power block
Andy
12-12-2001 16:14:50
how can i tell the difference between a power block and a regular block on a G?
Larry W.
12-12-2001 17:34:55
 Re: G power block in reply to Andy, 12-12-2001 16:14:50
I believe it will say "power block" on the top. I have two A power blocks. Both have the words "Power Block" cast in raised letters on them. I would imagine the G head is the same.
Eric Horne
12-14-2001 05:50:56
 Re: Re: G power block in reply to Larry W., 12-12-2001 17:34:55
Larry is right about the raised letters but here is the rub. Sometimes people want to be sneaky at the tractor pull and grind the letters off.
If the block is off the tractor, you will see the bore is stepped down where the head bolts on.
If the block is on the tractor, look to see if it has any petcocks on the side or bottom. It is my understanding that power blocks did not have any petcocks. My "A" doesn't.
