440 ic gas crawler starter nose cone breaking
charles ethridg
12-12-2001 16:04:51
the nose cone over the starter bindex has busted and all the parts have fel down into the bell housing. this is the second time this has happend. the starter was a new one and should be the right one for the engine, does any one know what causes this? am getting tired of pulling engine to clean out housing and check ring gear!
thanks charles
Mark
12-12-2001 17:10:34
 Re: 440 ic gas crawler starter nose cone breaking in reply to charles ethridge, 12-12-2001 16:04:51
What usually causes housing breakage is the engine "kicking back" on the starter. This can be caused by the timing being advanced too far, or a cracked dist. cap. Also there is an outside chance that the starter is not kicking out once the engine starts or is engaging while the engine is running.
Richard in W V.
12-14-2002 12:12:25
 Re: Re: 440 ic gas crawler starter nose cone breaking in reply to Mark, 12-12-2001 17:10:34
check the thrusk play on crank movment in and out i had this to happen to a farm tractor several years back some had put rod and mains in it and didn;t put the thursk washers back in they were laying in botton of oil pan.hope this is not your problem but iwould check it out.
Big City
12-20-2006 21:16:47
 Re: Re: Re: 440 ic gas crawler starter nose cone b in reply to Richard in W V., 12-14-2002 12:12:25
Just was wondering how you like your tractor when the starter is not giving you problems? is it underpowered? Looking at one but unsure about the 2 CYL motor. Seems small. Thanks Big City
