420crawler track pad bolts what size
Harold
12-11-2001 18:54:30
what size are the bolts that hold the track pads on the 420 crawler and what size is the inside diameter of the muffler that goes on the 420 crawler.
MIKE HANLEY
12-11-2001 20:06:46
 Re: 420crawler track pad bolts what size in reply to Harold, 12-11-2001 18:54:30
I think I used 5/8" x 2 1/2" Grade 8. The parts book dose not show bolt size only a part number which usually means in "J.D. that it is not a off the shelf bolt, and that part # was subbed over three times. I run a straight pipe on my 430c and used a 2" O.D. pipe and had it expanded to fit over stock exhaust pipe (part #AT10523T) (the short pipe that bolts to the manifold).
MIKE HANLEY
12-12-2001 15:26:16
 Re: Re: 420crawler track pad bolts what size in reply to MIKE HANLEY, 12-11-2001 20:06:46
ADDITIONAL: The reason the J.D. bolts are not off the shelf is the length of the bolt comes out flush with the end of the nut. I put on a washer and a Lock and a little of the bolt comers past the nut. A three foot long pipe on the end of the 3/4" braker bar and give it every thing you got,then just a little more. use only grage * bolts.
