A not-too-important question
Stan - Florida
12-10-2001 12:27:56
The cast rear wheels on the late '40s A, B, and G tractors had four openings in them. These openings were shaped so that you could put a chain link through them and pull the rear wheel out on the axle (we used a hydraulic jack).
On the later ('51-'52) models, especially the A and the B (not sure about the G), there were four more holes added - they were round and formed the corners of a square pattern in the wheel.
Does anyone know what these additional (round) holes were for?
Thanks,
Stan
jdman (Mo)
12-10-2001 18:13:50
 Re: A not-too-important question in reply to Stan - Florida, 12-10-2001 12:27:56
The only thing I have seen holes in the rear cast wheels for is to bolt those 150# wheel weights on. I thought those square holes were made so that when using a carriage bolt, you could remove the weights without completly removing the bolts. Russ
Stan - Florida
12-10-2001 18:42:04
 Re: Re: A not-too-important question in reply to jdman (Mo), 12-10-2001 18:13:50
I couldn't agree more, but what are the round holes for (in the latest versions of the styled A & B tractors)?
Stan
jdman (M0)
12-10-2001 18:57:15
 Re: Re: Re: A not-too-important question in reply to Stan - Florida, 12-10-2001 18:42:04
We had better ask Clooney. Russ
Frank-in-Tallahassee
12-10-2001 15:54:18
Stan:
While the holes on the cast wheels would accept a chain, which could be used to pull the wheel outward, I thought they were originally placed there to accept wheel weight bolts...the squared headed kind.
Sorry, but I haven't a clue on the 4 holes added later...I know my 70 has these, too.
Though I know from experience that you can pass a log chain through them and around the tire and create a tire chain of sorts when and if you ever get hung up on ice, though I haven't had the need for that for some time. Hasn't snowed in north Florida for a while !
70D // 855
jdman(Mo)
12-10-2001 19:43:10
 Re: Re: A not-too-important question in reply to Frank-in-Tallahassee, 12-10-2001 15:54:18
On the 70 we use those for round holes near the outer part of the casting to add duals. Russ
12-11-2001 09:01:08
 Re: Re: Re: A not-too-important question in reply to jdman(Mo), 12-10-2001 19:43:10
Wow !! I didn't think those holes would take that kind of strain !
We used a set of t-rail duals, and they had eyebolts that replaced four of the wheel nuts, and then the clamps drew up on those.
I still have the duals...it really made that 70 look big !
70D // 855
