B JD Axles
Stormy
12-10-2001 12:13:05
Can the B 10 spline axle on the unstyled be changed to the later model 12 spline axle. What would be involved other than the actual removing and installing. I have 12 spline B steel wheels I'm wanting to use.
mark
12-10-2001 14:55:17
 Re: B JD Axles in reply to Stormy, 12-10-2001 12:13:05
I beleive the differant bearing and cup relate to the rear axel houseing not the diameter of the axel.
I would compaire the ten spline axel side by side to the 12 spline then measure the bearing surface on the axel.
they should be the same.
I know that the BW 10 spilne axel was used past the the 1939 model year which leads me to believe that the difference is in the housing not the axel.
hope this helps.
WTW
12-10-2001 14:31:41
The 12 spleen axles will not fit the 10 spleen axle housing because the bearings races have a different outside diameter. You can put the complete 12 spleen axle housing assembly with axles on the ten spleen tractors and it will fit the tractor case. Bull gear outside diameter and tooth count are the same on the 12 spleen axle housing assembly. 1946 and older 12 spleen axle housings will bolt up to all the older unstyled transmission cases. a 1939 through 1946 housing will look allot like the unstyled long frame tractors but differ from the short frame models. The cultivator mounting pads are different from long to short frame models. Good Luck Dave W.
