HARD TO START JOHN DEERE HAND START
Johnny
11-30-2003 18:08:31
As per a post from Jim Cain a few days ago, I have a 41 model A with the same problem...exactly. I was hoping for a response from him if the suggestions given to him worked. I haven't been in the Magneto yet, but will do so this week. There is a snap, and a good spark, but as suggested, this might be a little weak. I know years ago whoever owned these tractors started them easier, so there's gotta be a solution.....
Thanks in advance for any advice/suggestions.
Johnny
Winnfield, LA
DRL
12-01-2003 08:00:49
 Re: HARD TO START JOHN DEERE HAND START in reply to Johnny , 11-30-2003 18:08:31
Tugboat has a point. When you are SURE that everything is set correct, and you have good blue spark, etc. . . you may then have to fiddle around until you get the right combination to get her to start up. Have a '44 B that likes half throttle, choked until it fires the first time.(usually about 2 turns) Then open the choke and she will fire right up on the next turn. Have a '40 H that likes throttle just above idle, choke for one turn, then open her up and she will fire on next turn. Have a '37 A that likes throttle about half way, full choke for two turns, then half choke the next turn and she fires right up. Took a lot of learnin' on all three to get combo right. I didn't need to workout for a while, especially when I was trying to learn on the A. You don't have to give that flywheel a very hard tug, just enough to bring her over compression with a little bit extra. The flywheel and the igniton will do the rest. Good luck.
Tugboat
12-01-2003 07:32:55
Johnny; When you get everything right, as listed below, you may consider the following. My 38 B starts really well IF I do the following. I set the throttle just above slow idle. I Pull it over once with the choke closed. I open the choke and pull it over again. It will start right up. The most inportant thing with this B is to do everything slowly including pulling it over. If I try to pull the flywheel too fast I can pull it all day long and it won't start. As soon as I slow down she starts right up! I don't know why, but it works for my B and me!
Tugboat
old
11-30-2003 19:57:07
What type of wire are on it they should be wire wires not carbon. How are the plugs are they gaped right, hows the timeing.Also don't feel bad as I might be asking the same question in a few days I just ordered a new Mag for my JD-B and I hope it will start like it did when I was a teenager, But with my luck it won't. LOL
