John Deere 952 wagon running gear
Gman
12-08-2001 18:15:34
Did John Deere ever market a rubber tired spoke wheel Wagon running gear such as the 952.The 952 came out in 1936 but I can't find any info if they had spoke wheels,they have the bolster springs front and back.I got a picture of a earlier rubber tired spoke wheel wagon being pulled by a John Deere D at the factory????? ?? would appreciate some input concerning this type of running gear.I'm restoring a John Deere 952 running gear and I put spoke wheels on it. Gman
Stan - Florida
12-10-2001 12:15:59
 Re: John Deere 952 wagon running gear in reply to Gman, 12-08-2001 18:15:34
I have a reprint of a 1937 "Power Farming with Greater Profit" book published by Deere. In it is a picture of a 951 "trailer gear" and it talks about a 902 running gear as well. The picture shows 5 spoke wheels with demountable rims and the running gears feature Timken roller bearings, heavy duty springs, one-piece bolsters, telescoping coupling pole (reach) first-line tires, auto-steering and replaceable bushings.
Stan
JHILL
12-10-2001 09:47:22
I have a JD model 801 running gear that has 16 inch spoked wheels. I believe it was made in the 30s
LARRY NEWMAN
12-22-2002 16:54:24
 Re: Re: John Deere 952 wagon running gear in reply to JHILL, 12-10-2001 09:47:22
I ALSO HAVE A 801 RUNNING GEAR WITH SPOKED WHEELS AND THE NUMBERS 21 AND 39 PLUS JD AND D EMBOSSED ON THE SCREW OFF HUB COVER. PLAN ON COMPLETING THE WAGON WHEN I FIND A FRONT WHEEL.
Jerry S
12-10-2001 09:34:16
I have a couple wagons that are JD running gear that have 6.00 16 tires on it that have spokes. I am not sure if a 952 is a high wheel wagon or what. I have a picture of a mid 30's B pulling a wagon like the one I have so I am guessing there must be several out there somewhere. Must have been made in the 30's I guess. Hope that helps you.
Clooney
12-08-2001 19:00:04
Gman, I know I have a picture of the 952 (somewhere) but at the moment I can't find it, if I find it I will scan & send it to you. Isn't CRS great?
Gman
12-10-2001 17:20:12
 Re: Re: John Deere 952 wagon running gear in reply to Clooney, 12-08-2001 19:00:04
Thanks for the come back fellows I've been to shows farm sales and you name it,and haven't run accross a rubber tired spoke wheeled wagon. So I purchased a 952 wagon gear and machined (phew) wheels to fit the 952 axle,and machined a plate for the screw on JD logo hub caps,it looks nice but that machinist bill was a lulu. Bet you dollar to a donuct I'll run accross one after I get this dude built.again thanks for the reply Gman
