Model 70
55 pick-up
12-08-2001 17:13:14
My tractor was only running on the rt.cyl.
it dosen't have any compression on the left side, so i took the valve cover off & the lock nut for the left intake rocker was laying in the valve cover.The other valves are ajusted way out. The left exhaust ajuster is broken in the rocker arm.
The rt. cyl. rocker ajuster lock nuts are only on by a thread or 2 and there's still over .100 valve lash! So is the base circle on the cam wiped out or do i have mis-matched valve train parts. Or or or ??? I need help Thanks
Clooney
12-08-2001 17:33:42
 Re: model 70 in reply to 55 pick-up, 12-08-2001 17:13:14
55 pick-up, I don't know how you could wipe the base circle of the cam out as the lifters don't put any pressure on the cam on the side opposite the lobes. It sounds like you have a parts mis-match or the wrong push rods (there is a difference between gas & all-fuel) or the lifters are extremely worn (unlikely), or the valve stems have been shortened or seats raised for some reason.
