Aux. valve on numbered JD's
Eugene swia
12-08-2001 05:19:18
Two different post's below on adding valves on 50-830's. Constant pressure on hyd system will wear out the idler gear and shaft in the governor housing. Customer had a 630 with a valve plumbed for a loader through the remote couplers he went through 2 gov. housings before he traded it off. We tried teeing an additional oil line to idler shaft for lube but still wasn't enough.Still think if he flipped remote valve off when he was grinding feed it would've helped. Something to keep in mind. Gene
