620 power stearing
Mike
12-07-2001 10:45:16
My 620 power steering does not respond. The fluid level is ok! Any ideas on how to fix. Thanks..Mike
Clooney
12-07-2001 17:04:08
 Re: 620 power stearing in reply to Mike, 12-07-2001 10:45:16
Mike, is the fan turning when the engine is running? If not you have found your problem. If the fan is turning we will need a little more (actually a lot more ) tractor & steering history to be of much help to you. It could be anything from a failed pump to a stuck relief valve to a malfunctioning steering valve to ?. Has it ever worked? Did it just quit or slowly get worse? Does it try to work at all with the engine running? The more info you furnish the more you will like the answers.
