47 b loader problems
Larry
11-30-2003 16:34:23
I just bought a #45 loader for my 47 b. I got all mounted up. So I gave it a try. It seemed to go up slow and the pump seemed to make a lot of noise. So I added some hyrofluid it rasied faster but still made the noise. I was reading my owners manuall. It said to use S.A.E. 30 in it should i drain the hydro out, and put the 30 in it? Also when i rasie it seems to settle about a foot before it stops. Do i just have air in the hoses/cylinders? If so how do i get it out? Thank Larry
CJDave
12-01-2003 14:40:29
 Re: 47 b loader problems in reply to Larry, 11-30-2003 16:34:23
Larry..... we experienced the same thing with our Number 45 loader when we first installed it. it took forever to get all the air out of the hydraulic system. Because the Power-Trol holds so little oil, you have to keep topping it up and topping it up until it finally quits asking for more oil! You WILL have to go to 30W non-detergent in that system to get it to work right.
CASEPOWER
11-30-2003 19:01:05
I would drain and refill. Depending on what hydro fluid you used it may be to thin most is 10 weight. A lot of noise from pumps come from the pump starving for fluid. You should be able to cycle the loader and loose the air. Make sure you have enough fluid also..
