John Deere Rear Axle Bearings
Mel
12-06-2001 15:35:40
I have the rear axles out of a 43 model B. I bought new oil seals and felt washers and have cleaned the dirt and grime out of the roller bearings. I know I should pack the outer ones before installation, but should the inner ones be packed or are they supposed to only get lubricated by the gear oil in the transmission/rear end unit. Do any other bearings in a Model B get packed or do they also depend on being lubricated by either crankcase or tranny oil? Does bearing grease work when in contact with gear oil?
dave g
12-06-2001 21:18:28
 Re: John Deere Rear Axle Bearings in reply to Mel, 12-06-2001 15:35:40
If you choose not to pack the bearings, you might find it easier to reassemble if you put some grease on the inner bearing so it will stick to the race and hold in place when you push the axle back in. Putting them in dry is REALLY hard, I tried it. I usually keep a pump oil can full of new gear lube to squirt on everything and saturate it with oil, then rotate it a few times and oil it again so I'm sure there's oil in there for the next while. When it's done I like to drive around in high gear for a while (just for the oil, he?:) to get it circulating. Good luck!
Tom in Mo.
12-06-2001 17:30:49
I agree. It usually takes months for me to run the tractor enough to circulate the gear lube.
I like to use Lubriplate light grease for the initial bearing installation and a very light coat on new seals (rubber).
Clooney
12-06-2001 15:53:46
Mel, I usually pack the inner rear axle bearings before installation as sometimes it will be months before it gets filled with fluid or driven. If you are going to put it back together & fill & use it right away then just put some gear oil on the bearings & seals & re-assemble it. The other bearing that needs packing with grease is the outer clutch pulley bearing. Gear oil will eventually wash the bearing grease out of anything that is packed & run in gear oil.
