4010 PTO hydraulic
Steve-Ga.
11-30-2003 15:57:46
Thanks for the help on PTO pin,put together like orig worked out fine.Need advice on Hydraulic knock,after tractor has been used(not just warmed up)THere is a knock,when the hitch is raised or remote used it is silent while in use?any ideas,and does pump have to be removed,if so does the front end or gas tank(or both)come off?
S. Conner
11-30-2003 22:29:02
 Re: 4010 PTO hydraulic in reply to Steve-Ga., 11-30-2003 15:57:46
The best thing to do is replace the coupling with one for a 4020. I've done this before and it works fine.
JDave
11-30-2003 17:22:00
Replace the drive coupler bushings that connect the pump drive shaft to the front engine pulley
