John Deere 620 clutch problem
Dennis Peto
12-05-2001 16:08:09
I was driving my 620 the other day and it was loosing power, it appeared the clutch was slipping, so I removed the cover, tightened the 3 nuts. I got my power back, but the clutch will not disengage. When I push the clutch lever in or out there is a nice pop to it, but pulling it back does not disengage it. Help???
Dennis
andy
12-05-2001 20:06:14
 Re: John Deere 620 clutch problem in reply to Dennis Peto, 12-05-2001 16:08:09
I had a John Deere 70 that would slip under a heavy load and also not want to completely release. When you would tighten it up it would never release. I took off the pulley cover and took off the three adjusting nuts and started pulling various pieces out. The entire assembly was filled with clutch fibers and rust. The plates that fit over the adjustment studs would not slide easily on them. Therefore it would not slide out or open when disengaged. Even though the various parts only move a fraction it was hanging up. I took it all apart ... wiped it clean, scraped the rust and corrosion from the holes and studs so they would slide easily and it worked fine upon assembly. The tractor spends some of its time outside .... which I am sure does not help.
Clooney
12-05-2001 19:45:28
Dennis, if the clutch was releasing good before the clutch adjustment & won't after the adjustment you could have any one of a number of problems. As Mike said you could have a brake adjustment problem, or you could have a clutch fork travel problem or step wear on the adjusting bolts, or overheated return springs from the slipping clutch. Due to the fact that it will snap in & snap out it doesn't sound like sleeve, toggle, pivot pin or dog wear. The first thing you have to do is try to figure out what is causing the problem before disassembling the pulley. Try to disengage the clutch with the tractor in gear by only pulling the lever far enough rearward to get the snap (no farther) & see if it quits pulling, then start pulling the lever farther rearward & see if it starts to engage again (if so then you have a fork stop adjustment problem or loose pulley brake adjustment. If it won't disengage with the lever just pulled to the release stage then suspect weak return springs, step wear on the adjustment bolts, not enough fork travel because of incorrectly adjusted fork stop(s), or actual damage to the clutch plates. One thing to check is with the engine off & the clutch dis-engaged with trans in neutral see if the pulley can be moved in & out about 1/4"-3/8", if not suspect fork stop adjustment. Then do the same test only drive the tractor then leave it in gear then release the clutch then shut the engine off & see if you have the same movement, if not suspect step wear on the adjusting bolts. After you have a little more info post back & we will go from there.
MIKE HANLEY
12-05-2001 18:01:20
You need a I&T manual. Your proublem is covered on page 40.to 43. Try ajusting the pulley brake adjustmemt. There are early and late model styles.the change was at serial #6217317 This ajustment is related to the clutch. When the cluch is "snaped" in the cluch is fully engaged.
When you pull back on the lever and the cluch disengages, you should be able to turn the pully back and forth by hand. Then pull back on the lever to engage the break pully. Try that first. If that dosesn't work you have to pull the pully and have a look see. The dogs may be worn and when you make the ajusment they are in one place and then move enought to trow off your ajustment. The pins holding the dogs in place have been knowen to lose thier cotter key, (Blame that on the previous.) owner The cluck ajustment is covered in the ops manual, but the pully brake ajustment is not and I have always wondered why not as they are related ajustments.
MIKE HANLEY
12-05-2001 18:23:09
 Re: Re: John Deere 620 clutch problem in reply to MIKE HANLEY, 12-05-2001 18:01:20
OPPSSSSS ,,,,I guess I should read before I type!!!!! !!! It's been awhile since I read the ops manuel. Proves the point that one should go back and read no matter how many times one has worked on something. The brake pully ajustment IS covered in the ops manuel. The operating Pin for the pully brake operates off the clutch fork and has been knowen to hang up. Make sure that the pin is clean and free so that the clutch fork works free.
MIKE HANLEY
12-05-2001 18:46:22
 Re: Re: Re: John Deere 620 clutch problem in reply to MIKE HANLEY, 12-05-2001 18:23:09
One other thought before you pull the whole pulley. If the clutch was slipping and the clutch got hot, you could have a broken fiber disk. I have seen them broke in two and then the broken piece over laps when the clutch is disengaged and then you make your ajustment but when you disengage the clutch the over riding disk will cause the clutch not to full disengage.
