JD 60 oil line problem
Moose
12-05-2001 00:15:15
I just put the crankshaft back in my JD 60, and I am having a heck of a time getting my oil line connected to the main bearing on the flywheel side. Anyone got any tips for me. I would really appreciate it.
Jerry S
12-05-2001 10:58:01
 Re: JD 60 oil line problem in reply to Moose, 12-05-2001 00:15:15
Haven't done a 60 but wonder if it would help to undo the other end of the line until you get the end under the crank bearing started? I bought a little mirror that helps me see behind things and comes in real handy. Might just need 4 feet long arms with about 3 elbows.
Clooney
12-05-2001 05:18:40
Moose, I usually start that line before tightening the main bearing housing. I rotate the housing & fitting up then start the line then rotate it down & bolt the housing up.
