How doo i Blance out the flywheel????
Adam
12-04-2001 13:29:34
I have a John Deere B and it shakes really bad i need to know how to balance out the flywheel please email me [email protected] and if you would go step by step. Thanks
John T
12-04-2001 14:19:37
 Re: how doo i Blance out the flywheel???? in reply to Adam, 12-04-2001 13:29:34
Adam,,,,, if she shakes real bad thers a good chance either the flywheel OR the clutch disk is one or more splines off of time. Its probably whichever was removed last, and if the flywheel was never moved, then of course its the clutch disk. There are v marks and dots on the clutch disk/crank so I would check that first. One way to know its in balance, is if the out of weight on the disk is exactly 180 opposite the out of weight on the flywheel. Good luck Ol John T
Kelly
12-05-2001 19:31:51
 Re: Re: how doo i Blance out the flywheel???? in reply to John T, 12-04-2001 14:19:37
John T., I've got a 45 JD B electric start with a beat-to-hell flywheel. Someone used a sledgehammer to beat it on the crankshaft and marred the surface something awful. The ring gear is also broken. I found another one in good shape to replace it.
My question is: will the replacement flywheel be balanced with this engine or will I need to have it re-balanced? I understand that the original flywheel and engine were balanced at the factory as a unit.
Thanks for your reply.
Clooney
12-06-2001 08:58:44
 Re: Re: Re: how doo i Blance out the flywheel???? in reply to Kelly, 12-05-2001 19:31:51
Kelly, it doesn't look like John T. got a chance to go back & check his old posts..... In Theory the flywheel, pistons, rods, crankshaft & clutch driver should be re-balanced as an assembly when a new flywheel is installed. In reality hardly anybody ever does. If you don't develop a different or worse vibration after the new flywheel is installed I wouldn't worry about it. Even then you can add stick on wheel weights in different locations & work your way around the clock & run it to evaluate the change in vibration until you get it to run smooth, then remove the same amount of weight from the opposite side by drilling so you can remove the stick on weights.
John is 100% right
12-04-2001 18:09:32
