John Deere H information
gary
12-04-2001 07:02:42
trying to find some information on the drive gears of a John Deere h does anybody know of the little H.
was offered with different gears? no other models(different years)
had gears a couple teeth different
running from the clutch 2 the final drive or differential
gary.
Clooney
12-04-2001 07:23:00
 Re: John Deere H information in reply to gary, 12-04-2001 07:02:42
Gary, the H used some different trans & 1st reduction gears over it's history with a big change at S/N 10,000 but I believe they never changed the tooth numbers or ratios, at least not that I have ever seen or heard of. I believe they all used a 72 tooth reduction gear which would require the pulley gear tooth count to stay the same even with the gear change at S/N 10,000.
gary
12-05-2001 05:24:54
 Re: Re: John Deere H information in reply to Clooney, 12-04-2001 07:23:00
hay clooney thanks for the information
a man can always hope
I was not only thinking of changing the reduction gear but rather trying to find out if it was possible to find a different reduction gear end the pulley gear I was thinking if they never produced what I'm looking for perhaps I might have to have some custom ones made thank you again gary.
