37B Oil leak at pulley
difficult or easy fix?
David
12-03-2001 17:57:19
Have 37 JDB in good shape but has a slight oil leak at pulley. How hard is it to tear down clutch(?) etc and put in a new seal?
Clooney
12-03-2001 19:33:35
 Re: 37B Oil leak at pulley - difficult or easy fix? in reply to David, 12-03-2001 17:57:19
David, exactly where is it leaking, at the pulley to dust shield area, behind the dust shield, or at the clutch cover? Some leakage is normal behind the dust shield, especially if the engine is run very long with the trans in gear & the clutch released. There isn't an actual oil seal in the pulley it is more like a catcher to catch & return the oil to the 1st reduction cover. If the oil leak is excessive there are a few things it could be, too big of a R/H main bearing clearance allowing too much oil to flood the pulley & sleeve area, worn operating sleeve to pulley, failed dust shield to 1st reduction cover gasket, plugged pulley bearing drain holes, plugged 1st reduction cover to crankcase drain holes, or excessive combustion blow-by, or more than one of the above.
joe
12-03-2001 18:23:12
it isnt any problem to tear it down and put a new gasket on it.I had to do it to mine.
